Well as some of you know I had problems with my car losing power then kicking back in all of a sudden. First we thought electrical, but the mechanis said no, then the fuel filter...but apparently not.
Complete auto here in Whyalla is where i took it. They serviced my car, changed alot of piping and some other random junk. Costing around 700. They rekon they fixed the problem with what they did.......but they didnt. Now the rekon it could be the knock sensors i think they said, anyways they said theres two of them in my car. And they want to charge 1grand EACH!!! Lucky for me it was dad who has been paying everything.
Anyways dad's taking it into adelaide this weekend so hopefully somewhere there can help with the problem. Is 2 grand too much? AM i getting ripped?
Thanx >_<
Edited by Whyallapunk
https://www.sau.com.au/forums/topic/170416-pricing/
i think you're being taken for a run. sounds like they have no idea what they're looking for and simply changing whatever they think needs to be replaced.
diagnose your problem at a reputable mechanic - do it first time, do it right.
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3147512
FAAARRRHHHKKKK
for that sort of money, take it to an RB specialist tuner
much cheaper :/
and um, i was under the impression Non-turbo's didnt have knock sensors???
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3148173
  • 4 weeks later...
Thanx :cheers:
Howdy, this was a while ago but incase you check back here, where did you end up taking it in adelaide and how did it go? I'm in adelaide looking for somewhere to go for an N/A R33 service and some brake pads/gearbox work.. but all I have at the moment is a few places I know to avoid, nowhere recommended.
Seems either you go to a regular garage who is cheap but has no idea about skylines and cocks it up, or you go to a specialist garage who charges like you've got bottomless pockets and doesn't necessarily do the job any better unless you happen to know them.
There is a genuine nissan garage near my place but they quoted nearly $500 just to replace the front & rear brake pads. :D
With genuine nissan pads no doubt, i'm more keen on something aftermarket thats decent and reliable and costs alot less.
Any suggestions? must be some SA ppl here with some idea's..
Cheers
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3192920
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
