TD 42 and td petrol use the same bottom end dan. the 4.5 and the 4.8 petrol jobs are also the same aprt from bore and stroke.
If you are gonna do it grab the 4.5 petrol number. Its a free 500 cc. The 4.8 would be the killer given that it already has the right head but its a bit thin on the ground.
Yeah but the TB45E has a bore/stroke of 99.5/96 whereas the TD42 has a bore/stroke of 96/96
The 4.5 will not rev as high as the 4.2 and the rod length/stroke ratio is right on for maximum torque and still being able to see 8k rpm.
I'm picking up the GT51R at the end of the financial year. :sorcerer:
  • Replies 222
Posted Images
well screw you all im building my dream xp falcon after the cefiro is finished, it will house a twin turbo 347ci small block ford than will make rb's tremble at the knees.
Ford...snicker snicker. tee hee. Oh fucit. ROFL
Yeah but you asre forgettng something very important....at the end of the day.....
when all is done.........
and everyone has left.........
it's still a bloody FORD!
yeah sorry i can slot a hemi in there, not quite enough room.
go check out the trick and mansweto (sp) capri and tell us if a small block chev can crank like that thing
Quite sure. Mouse thats m.o.u.s.e. The rat family are the big blocks. Mouse motors are small blocks. Ya wanna rev get a chev. :P
dude i may be young but i know more about the old stuff than any thing else, and nothing revs like a small block ford.
but people have been having this same disscussion for more years than i have been alive and its never been settled so lets agree to disagree.
^^^^^^^ford power^^^^^^^^^
Agreed. :P
Agreed. :P
see who said that the qld section needs moderating when there is gentlemen like noel and myself around
by the way RB20 RULZ !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
