  • Replies 222
Posted Images
She's great Noel, your a lucky man...
But other than that I give you 2 gold stars for your engine knowledge, your general knowledge is far higher than I first gave you credit for... :P
he gets it all from me :D
My economy is awesome....1 tank of fuel lasts me like 2-3 weeks easy. I found out that by driving a work ute instead of the skyline, my fuel economy has improved and my wallet is fatter! :P
donate to the Get Shane's Car Back On The Road fund and eleviate some of that fatness :D
BS...you get it from me. He used to get it from you but then he found out you don't listen to me so he bypasses you now and rings me instead.
And sif you need funding...you live in the Switch! don't the government fund you guys?
hahaha yeh government funds the switch and it locals..lol.Give centrelink your sob story, your a full time uni student lives away from home, you have kids with no partner and your 1/8th aboriginal, while at the same time working a full time job, and then doing weekend work for cash. If i lived in the switch thats what i would do...youd be on like 2g a week easytown.
And let's not forget...that's almost a dry sump setup.
Unless you do what Shane did and buy a pump that's come off a NASCAR. Then the pump is only about $350 but it's already had 10 hours at 8krpm
lol... still like u to fine me someone who put a RB20 into a SR20 powered car. besides SR halfcuts are 3k+ wher as RB20 are 2k or so..
lol who was complaining about std SR oil distribution... look at the RBs haha.. rev it for too long and all ur liquid gold is in the head.. booyah.. bye bye big ends.
.. sound similar to ur GTR shane.. big end failure.. BANG
Really? mine doesnt have that problem. I got a nifty little oil pump that hangs off the side of my block, where the a/c would normally sit, infact the only oil in my engine is whats running through its veins doing its job, straight afters its done what it needs to it gets sucked out. My big ends are fine too.
Sr's biggest fault is their stupid rockerarm/camshaft design, nearly as stupid as pushrods in v8's...and two valves per pot....and because i hate chrysler/dodge stupid hemispherical combustion chambers!
Don't forget the alloy block is a bit of a nancy boy, it breaks to pieces after about 700hp. Then, of course, you have all the issues with the SR oil pumps. They rattle their arse off before taking a hike.
relays, pfffft who needs them :D
dude if i was even 1/50000th aboriginal i'd be claiming everything i can :P
if it works (which it should) who gives a fark where it came from/how old it is. ur just cut ur getting reamed for a new one :P
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
