I am very happy with the Wolf 3D plug-in myself. Do a search on both ecu's and you will find a wealth of information.
If you have a R32 why change you ecu, just get it rechipped? Even though i am very pleased with the wolf, it can never run as smoothly as the factory ecu. My problem was that R33 are not programmable.
i disagree that aftermarket ecu's can never run as smoothly as factory ones.
all you need is a good ecu, very competent tuner, and the money to keep going back for fine tuning.
afterall... factory ecu's are programmed by humans too... the only difference is that your average car manufacturer has a team of professionally educated boffins trained to tune their motors and the money to pay them.
if only your average joe was so lucky.
Well I think that aftermarket ECUs can run as well as stock ones, but if you go modding too much eventually idle and low rpm will suffer - not much you can do about it as things like bigger cams, injectors, penums optimised for higher rpm etc - it all adds up, which is something alot of people dont seem to realise when they head down the mod path.
I am quite sure someone will tell me about a beast of a car that totally disproves the above, but it is just what I have seen and experienced -
0.182c not including GST:)
OK, i felt this topic too open.
What i ment was that Millions of dollars are spent by the manufacturers to make an ecu run the engine and other parts, IN STANDARD FORM, really smoothly. This includes, cold, warm and hot start ups, fuel economy, a/c, and a whole lot of other shit.
I am very pleased with the running of my ecu and have no further problems, but with a R32 on can modify just the required areas/fields of the map to receive a VERY similar result.
Just my 2c
Alan
Guest drift_me_silly
it all comes down to application...for street, the factory chipped computer will always be the best value for money...and i hear what Turbo titts is saying; finetuning that takes place at teh factory has to take place at a workshop paid hourly by you to acheive the same or better results...the one and only thing that will always sway my mind back to the aftermarket is the resolution. -that also affects my choice of comp....but always, the resolution will be the defining factor of how thoroughly you CAN tune it. money money money......all that money....
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
