Which format is the Japanese version 360 console? Mine has Japanese written all over the box and all Jap menus so I assume its the Jap version. (since it was a gift I have no idea where it was originally purchased)
If its NTSC, does that mean it can not play any PAL games sold in Australia?
If thats the case, where can I get it chipped so it could play all formats (ntsc, pal and/or DVD R)?
Cheers
A lot of xbox360 games are not region encoded. So some game will work and some will not. Only DVD movies from the japanese region will work on the console.
Also in the settings there is a menu where you can change it to english.
your correct skylvia.
Collectors editions are always nice if you like extras. Just be wary cos you have a hong kong console lots of games are gonna be in full japanese which could make it difficult for you.
No japan and USA are NTSC, and australia and europe are PAL. France i believe still use SECAM.
But with all this high def shit it doesn't make much difference anyways, it's not really pal or ntsc anymore, cos originialy i think pal had 576 verticle lines compared to 480 on ntsc, but ntsc had a higher refresh rate, but with 720P. 1080i, 1080P etc etc those old standards of broadcasting are out the window.
with XBOX 360 games, I've noticed that Japan and some other Asian countries have NTSC-J while North America has NTSC-C/U. Whats the difference there other than language? Are these different region coding games interchangeable/playable on both console versions?
I guess the restrictions are there just for marketing purpose then?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
