Hi
I just bought my 1st R32 and it doesnt have a battery clamp.
Can I just buy one of those in supercrap stores? I cant find any holes on the tray to poke the L shape clamps you get from supercrap.
Better if anyones here in Brisbane got a spare battery clamp.
Also when I 1st start the car it kinda wants to stall straight away unless I press the pedal once to get the rev up and it idles fine...
When I had a look at the car it wasnt doing this, but the battery was flat as it was sitting for a while. So the previous owner bought a cheap battery to replace it.
Could it be cos of the el cheapo battery couldnt handle 1st starts?
Also the light switch behind the gear stick one is for the lower inner light on the front bar and when you press is towards the back which light should be on? cos nothing is coming on.... is that for the outside light on the front bar?
Thanks
https://www.sau.com.au/forums/topic/171110-battery-clamp-and-a-few-questions/
You could just drill holes to get the L shape stick to hook up, I have a spare factory L shape thing but can't find the actual metal bar thats goes over the battery.
some pic of that light switch might help, bit hard to remember what's what without access to r32 now :)
Try getting a quote from nissan for interests sake. Might have to come from japan, takes 10 days. Ive attached a pic of the bracket and its part number from fast. Alternatively, try contacting nisswreck or any other imports wrecker. Or nissan silvia seeing as they use skyline front cuts in their sils.
I dont think u need over 400CCA to crank it up, 350 should be enuff. But that said some CCA of certain batteries are overrated or underrated. My deka etx30l is rated 365CCA, but when we tested it, its actually doing 470CCA.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
