buddy have you thought of dropping the price a little.. i understand how much money youve spent but if you want to really get rid of it id probably drop the price.. just my 2 centss
If you continue posting drivel like this in other peoples for sale threads, you will receive a warning.
Unless you are genuinely interested in purchasing the vehicle advertised, don't post.
https://www.sau.com.au/forums/topic/171320-sold/page/2/#findComment-3221314
Pics look to be broken temporarily - not sure why...
Check out these links in the mean time:
http://www.sewid.org/gallery/v/myCarGaller...ustPhotoShoot2/
http://www.sewid.org/gallery/v/myCarGaller...gustPhotoShoot/
https://www.sau.com.au/forums/topic/171320-sold/page/2/#findComment-3225565
