You should try Parramatta Road between Granville and Silverwater on your way to Ashfield...
holy shit...parra rd sucks soo badly...around the nike factory area and if u got coilovers its sooo bad
apparently parra rd is the worst rd in sydney...someone told me
Dude, nobody NEEDS to be told that to know it - it's a fact!
There's one simple reason why they'll NEVER fix Parra Rd: the tollway!
haha. I think I almost got airbourne the other week and that was doing less than the speed limit :D
Ive got airbone like that once on Parra rd, my car hates that road and any other F*cked up Sydney road!
Then again, mate, just remember what it USED to be like!
hahahaha.. yeah! I only really use it from the m7 up towards windsor rd, and thats all been redone, so its niceeee :(
what i really hate though, is if you do 70, that whole stretch, you will get EVERY SINGLE RED LIGHT!!! :D
oh god yes!!!! I try and avoid it as much as possible!! Usually james ruse to the end of parra rd.. and that little stretch sux! I tend to turn off and use the back streets as quickly as possible!
Nothing beats Lyton street blacktown, going towards richmond road its makes Sunnyholt feel like the M7
i know this road too well.
stick to the left lane and shift 1m to the left and you will avoid most harsh bumps
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
