hey guys im about to install my super coppermix clutch and i want to set it for the 1,000kg clamp pressure.. any idea on how i will do that? does it come like that from the factory? or would i need to set it to that?
https://www.sau.com.au/forums/topic/171574-nismo-super-coppermix/
  • 1 year later...
  • 9 months later...
I got a problem with my coppermix. I got a single plater for a 33gtst. After the job was all done, I found it incredibly hard to select gears, specifically 1st, 2nd, and reverse. I started to do a bit of troubleshooting, so I did a bleed on the slave and master clutch cylinder. After that didn't work I removed and re-fitted the gearstick, to see if the problem was in the shifting mechanism. No good.
I started scratching my head a little, and this is where I need your advice guys!
I remembered back to fitting the new thrust bearing that I got with the clutch kit. I'd whacked off the old bearing carefully with a rubber mallet. I then pressed on the new bearing. I noticed that the new bearing sat shorter on the old bearing carrier then the old bearing. I didn't think this would be a problem at the time, but now I think it's causing my clutch to not fully disengage, because the bearing is shorter it's not pressing against the pressure plate as much as the old clutch. And now it's messing up the synchro's in the gearbox.
Could this be a good reason for the gearbox playing up? Is it possible to get longer bearing carriers? Can I just get a whole heap of big washers to put on the bearing carrier (lol)?
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
