I need to sell a few parts to buy a new gear box.
Rear hubs r32 gtst $100
Rear driveshafts 5 bolt ones $150
Stock Diff, stuffed but good to lock or change internals $100
Stock Cooler and metal pipes $100
Air flow meter, turbo rb20 r32 $130
Front caster rods with whitline bushes to give more caster $150
or $100 exchange with std rods
2 stock wheels $100
**I have 2 front strut braces that are not painted to sell for $80**
I am in adelaide, make an offer on any parts you are interested in.
Every one i have seen have been stuffed, the bushes are about $100 so you get the fitting and some new rods as well.
edit: GTR are different if thats what you want them for.
The diff/driveshafts and hubs would be perfect to convert a n/a to 5 stud all you would need is the brakes for the rear.
I also have the cast crossover pipe and stock BOV .
I also have a front strut brace for $120.
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
