As some of you already know my 34 was broken into and im finding it really hard to find a quater glass window left hand side, can anyone help me find one. I have been waiting 2 weeks for a guy in Vic to pull one out of a 34 but needed so get a pro in to do it, but the dick head droped it and smashed.
Please help...
Llynden
P.S second hand will be fine
https://www.sau.com.au/forums/topic/171646-quater-glass-window-left-hand-side/
May be you missed my post when this first happend.
Did you try Phantom motors at Stafford they have a shit load of R34s in there yard.
They would probly get one or point you in the right direction.
damn idiot for smashing the glass. Anyways, have you tried the new wrecker opened up just down the road from us???
Mt Gravatt Auto Recyclers
2433B Logan Rd (Cnr Bleasby Rd, behind the Salvos) Eight Mile Plains.
07 3341 1522
I dropped in this week asking for an R34 sedan boot and they had one but had to order it in from a wholesaler. Give them a call!
P/S I spotted you driving past the BP at EMP just before..hope your car is not drenched :thumbsup:
any luck for the window?? by the way bro i got the headlights off mine since they bought new set for mine :thumbsup: your welcome to the side you want !
Try Cresta Wreckers - 32451555
RMA imports & Wreckers 07 55327914
All Jap - 38652221
Give them a go good luck bro
Edited by 53XYN
