hmmm yes you would say that, what i was just after was just some positive/negative feed back from people who have them installed, i know how they work and why you should put one in, but i want to know from drivers what they think.
how much do you sell them for?
acually one question, do they put any stress on the clutch packs in the transfer case.
Edited by robbieraver
details of our controllers are in the link in my sig, and I don't want to make this a for sale thread...
First up, if you are only looking at street driving there's probably not too much point. Where they really help is allowing you to tune the balance of the car in corners, you have the car's natural balance, tyres, suspension and then you can get more or less fwd to change attitude on corner exit. Also obviously helps in the wet with reducing wheel spin, presumably the same for big hp gtrs in the dry too.
Yes they do put more stress on the clutch packs, you can burn them out running too much front torque for too long - they are not designed to transfer significant torque all the time. We killed a transfer case at targa tas 2 years ago on a 50klm stage through snow running full front torque all the way.
In the end, the 32 had too much rear bias and a controller can fix that - you leave it on say 3 or 4 and enjoy the improved balance. Nissan obviously agreed they changed the system to have more front bias in the 33 and 34 - I have a stagea daily driver and it's front bias is much more than the 32 (it happily power understeers every time you floor it)
i run a torque controller supplied by duncan
and it works very well for us, we have done alot of racing over the two years it has been in the car(hillclimbs, sprints & tarmac rallies) and we are still using the original transfer case and we have not had to rebuild it.
i will say one thing though, if you 4wd system is not working properly (as most r32's aren't when they get to this age) all a controller will do is speed up the process of destroying your transfer case
oh & another thing, we did try a different torque controller that used a dial with percentages(10 stage adjustment) being directed to the front, this was a very sensative system and if you dialed in too much it would have killed the transfer case in a heart beat on circuit, not as bad for drag racing though.
cheers russ
Edited by giant
thanks for the info, that is the same sort of driving il be doing, not so much targa but hill climbs and track work, ive heard of one or two dead transfer cases down my way (melb) but thats some thing to keep in mind.
cheers.
Take you GTR to Racepace then.
They modify transfer cases inhouse :rolleyes:
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
