Hi all, ive finally decided to part with my baby or at least sell off all the parts for the "plan" to have a tuff gtr. over the years i have quite a bit collected so here goes. please do not pm me as i do not come online often. if you wish to contact me please email me at [email protected]. Please do not whinge on this thread about Joe Bloggs down the road is selling it cheaper. Should you wish to contact me please call on 0417755890 after 6pm. thanks
USED TOMEI FORGED CRANK, FULL COUNTERWEIGHT $3800
USED TOMEI 87MM FORGED PISTONS WITH COOLING CHANNEL NO RINGS $1550
USED HKS GT-SS TWIN TURBO KIT FOR RB26. EXCELLENT CONDITION. NO SHAFT PLAY WHATSOEVER. LIKE NEW WITH HKS STRENGTHENED ACTUATORS. DONE 3XXXKMS $2450
NEW TRUST GREDDY FUEL RAIL 11MM INCLUDES LITTLE BITS AND PIECES, $300
NEW REINIK (NOW KNOWN AS REIMAX) GROUP A OIL PUMP. THIS IS THE PUMP USED ON THE GROUP A GTR'S IN JAPAN. REINIK ARE RESPONSIBLE FOR THE 2.8L IN THE 400R $1100
USED NISMO WHITE CLUSTER SET INCLUDED ARE SPEEDO 320KM, TACHO 11000RPM, TORQUE, FUEL, WATER TEMP, OIL PRESSURE $900
USED ARC TWIN ENTRY INTERCOOLER, APPROX 70-80MM THICK $350
USED ARC REAR STABILIZER BAR 30MM $320
NEW WIDE FENDERS FOR BNR32 FRONT 30MM WIDER ON EACH SIDE. MADE IN JAPAN. STRAIGHT BOLT ON. MEETS UP WITH STANDARD BUMPER. UNPAINTED. $900
NEW STEP 3 22MM PIN H BEAM CONRODS, STEP 3 APEXI VMAX 22MM PIN 86.1MM PISTONS WITH RINGS AND PINS & APEXI VMAX CAMS IN/EX 260 11.2MM LIFT, APEXI VMAX LIFTERS $4500 THESE HAVE BEEN SOLD
USED TRUST OIL SUMP EXTENSION. WELDING ALREADY DONE. DOES NOT INCLUDE ACTUAL DIFF. $700
Im pretty sure i have other parts too, but i havent finished clearing out the garage. I'll post them as i find them.
Edited by AtomicBomberMan
They are some good prices for some serious gear some one that wants a tough GTR should snap some of this stuff up.Good luck with the sale mate.
Will you sepeate any of the Apexi parts?
hi, which particular parts are you interested in? please sms or call me 0417755890
wht11 i am happy to separate. please check your pm. if youre interested, please call on 0417755890
cheers
for those that have contacted me. i will be in cairns until wednesday. any equiries by phone or sms only 0417755890.
INTERCOOLER SOLD
can you pm me the specs on the apexi turbo's
turbos are rated to 340ps each. bolt straight on to standard manifolds. includes all stainless earls lines and fittings for installation. kit is brand new. gtr's are running 10's with these turbos.
What size is the compressor and turbine wheel? (even if u can just measure the bits u can see) A/R's? Let me know and I'll make a fair offer if they suit.
sent you pm. please check. http://www.apexera.co.jp/carlife/pro_apexi...URBO_syogen.pdf
Where about in Brissi are you? Im keen on the arc cooler.
im located on the west side indooroopilly way. can meet up if needed.
cheers
  • 1 month later...
gauges are sold
oil pump sold
crank and intercooler people are stuffin me around
parts can be found on ebay with rb26 or gtr as keyword
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
