It wouldn't fit the plug for a start as the Stagea is 3 row and the R32 2 row. It would work if piggybacked on to the S1 ecu (I had one on mine) but its a lot of work. In fact mine is floating around for sale (or was in the stagea for sale sectrion). Greddy e-manage would be simpler esp if you can find a suitable loom exetnder and adapter.
  • Replies 62
Posted Images
II've heard that if ya disconnect your battery for 24 hours( or place ya foot on the brakes to drain ya battery) then reconnect it, it will reset the ecu to the original setting improving response, gear change and economy.
Anyone want to comment?
Yes probably worth doing if you have changed your fuel for a different octane rating but as you have a S2 you should get a Nistune chip and then your car can be tuned properly.
