sorry inbox full. didnt realise.
thought it was weird that i had no PM's.
Sorry matt .
tried to call u wekks ago.
if u still have it im keen.
Had internet dramas aswell.
sskyline....please re send PM's.
someone asked me what they do and how can they benefit from them....
well heres an explantion.
(stolen from wikipedia)
Suspension Tuning
Caster
Caster is the angle between the steering axis and the vertical axis as viewed from the side of the car. Caster affects straight-line stability and "camber gain". Positive caster is when the top of the steering axis is tilted back (steering axis intersects the ground in front of the tire contact patch). Negative caster is when the top of the steering axis is tilted forward (steering axis intersects the ground behind the tire contact patch). I have never seen negative caster used, and I do not believe it is beneficial in automobile suspension geometry. Therefore, for the rest of this section, when I refer to caster, I am talking about positive caster.
To visualize caster, think about the wheels of a shopping cart. The steering axis of the wheel intersects the ground far ahead of where the wheel touches the ground. As a result, the wheel is essentially dragged behind the steering axis. This keeps the wheel moving straight. If the steering axis intersected the ground at the same spot that the wheel touched the ground, then there would be no caster effect. The wheel would be free to spin around the steering axis as long as it was not held in place by some other force.
Unlike in a shopping cart, the steering axis on a car is placed close to the hub of the wheel. Therefore, the only way to make the steering axis intersect the ground ahead of the tire contact patch is to tilt the steering axis. The more the axis is tilted (in the positive caster direction), the greater the caster effect.
Example of Positive Caster (Side View)
Enlarge
Large caster settings increase the tendency of the front wheels to center themselves. This tendency is mainly due to the camber gain that occurs when the steering axis is tilted and the wheels are turned. Camber gain involved with caster is not easy to visualize. Think about the extreme case where the steering axis is tilted to the point where it is horizontal. When you turn the steering wheel, the front wheels would stand up on their edges. If you turn left, the left tire will stand on its outer edge, and the right tire will stand on its inner edge. If you turn right, the left tire will stand on its inner edge the right on its outer edge. The same type of camber gain, only on a smaller scale, takes place with less caster. This camber gain is exactly what you want in a corner. Read the previous section on camber to see what it is and why it’s beneficial.
When the tires stand up on their edges, the front of the car is actually raised up. This is why the wheels "center themselves" when you let go of the steering wheel. The weight of the car pushes the wheels flat on the ground, which resets the steering. This improves high-speed stability because it keeps the steering firmly in the center position. However, it is difficult to turn a car with a large caster setting because, while turning, you are actually lifting the front of the car with the steering. This effect is most visible in luxury sedans, where high-speed stability is important and sophisticated power steering makes up for the extra steering effort. If you watch one of these cars as the wheels turn to full lock (maximum steering angle), you will see the front end of the car rise slightly.
Increased caster is advantageous for racing and, in some cases, street driving. The only disadvantage is the added steering effort. While camber gain due to caster is generally good for increasing the grip of the front tires in a corner, too much camber gain will cause the tires to heat up, lose grip, and wear out prematurely. Therefore, do not use more than a few degrees of caster. If your car uses a MacPherson Strut suspension, it may be necessary to modify or install new strut tower mounts to be able to adjust caster.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
