Hi,
About 2 weeks back i purchased a original style Apexi RSM. I was brand new when I received it and I paid $118 delivered to my door.
Just yesterday I purchased a safc and blue screen rsm as a package so now I have the old rsm (which is basically brand new for sale.
I would like close to what i paid for it as I only used the thing for 2 weeks
$100 ONO delivered \local meet up if in brisbane
Does 1/4 mile times 0-100 etc
Has tyre size correction..
All the basic RSM features..
See manual here http://www.apexi-usa.com/pdfInstallation/14.pdf
Can supply pics if neccessary.......
Please note, sub loom (small loom on the right first pic) has been hacked at when I removed from my car last night (actually i used this to wire in my new rsm so I got away without going back to the ecu as they use the same wiring) everything else is perfect.. Just cut the plug off and extend the wiring..
Also will throw in an apexi rsm\safc stand for free.. 2nd hand just gotta clean the old double sided tape off and apply new stuff.
Edited by turbs33
https://www.sau.com.au/forums/topic/172581-original-apexi-rsm-100-ono/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
