I complained a lot in the O2 sensor thread (many pages long!) about poor economy.
I would consistantly get 350k's to a fill. (about 52L)
I changed everything, cleaned everything. The car was totally stock.
So i've put a 3" split dump pipe on, fixed broken studs, changed the cat (still stock from cat-back) and upped the boost to 10psi, and I get 380-400 to a tank EVERY TIME.
So... i'd put that down to an A/F ratio change. I'm using less throttle to get the same power because of the extra air coming in, so less fuel at that map-point in the ECU. You might have (as someone else suggested) a poor AFR. Cleaning the AFM should increase your usage, by my reasoning? If it can "see" more air coming in because it's nice and clean and not insulated with dirt, it will squirt MORE fuel to match. Oh well. Clean it anyway. ;o)
If your driving in the city/small frequent trips/lots of red lights its possible that your consumption could fall to a tank in 200k.
400k to a tank is with some freeway/normal driving.
Lots of short trips with lots of stop/starting reduce this significantly.
update - im on empty , with 330kms done . no red light yet , i guess you could say i have done a few small trips , lots of stopping and waiting in traffic...
im still considering changing the o2 sensor .
does anyone know if injector cleaner will help? and which specific one should i purchase.. ?
CHange the air filter. And get that Nulon injector cleaner, its about 10 bucks per bottle. use it for one full tank of fuel, run it empty and see how it goes.
i only put a pod on about 2000 kms ago , so no need to change that . but i will try the injector cleaner when i fill up again . should i see results if there are any , in the next tank with injector cleaner? or will it be the one after?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
