both th seats r identical, its jus the rail that differs, ive got interest in the drivers seat and rail, if i have no luck by next week selling as a pair im splitting them up, and if need be seperate the passenger rail from the seat if sum1 else wants it as a drivers seat, rails are only 200-250. but ill be asking 1650 for the seat only passenger only.
Edited by 747.GTR
https://www.sau.com.au/forums/topic/172620-sold/#findComment-3179368
they fit r34 GTR 100%. same as 32 n 33 GTR. let me kno if u wanna do a trade? these seats ARE THE BEST on the market from bride there is no better.
ill have pics tomoro of them installed in my 32 gtr, picking it up from the interior shop and droppin it off to have engine wired up! had full suede interior done!
Edited by 747.GTR
https://www.sau.com.au/forums/topic/172620-sold/#findComment-3179648
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
