Hey guys just moved over here from the Gold Coast. Didn't much choice in the matter :)
I'm out at RAAF Pearce (Bullsbrook), will be coming into town most weekends so will try and get to any events that are happening.
Have two questions for yas.
1) I need a set of coilovers for my '32 (GTS-t). Looking to spend round $1000
2) Need a Dyno tune asap. Who should I go to?
Thanks!
Kyle
https://www.sau.com.au/forums/topic/172621-hello/
You wont get a decent set of new coilovers for $1000. I sell Tein SuperStreet for $1895 plus fitting if you require it.
I assume you are airforce being in bullsbrook? I live in Ellenbrook. 10 minutes down the road. :)
Oh and welcome to Perth and SAU WA!!
https://www.sau.com.au/forums/topic/172621-hello/#findComment-3176904
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
