hey sau.
had a compression test done an 1998 r34 gts-t today with the following results.
Test was done at running temp with throtle fully engaged.
DRY
1. 187.44
2. 187.44
3. 186.02
4. 173.24
5. 184.60
6. 176.08
Then a few of the varying cylinders were done with a wet test.
WET
1. 214
4. 199
6. 213
These results seem very high ?
I have had mixed opinions about the results of this test.
If anyone from SAU please give me their opinion that would be greatly appreciated. ie Engine Health.
Thanks.
Tours
Edited by Tours
consistant results over all cylinders would be more accurate to define a healthy engine, ie all 170-175 or 180-185, cylinder 4 might be of concern. But having a varience from the highest to lowest of less than 10% is acceptable I think
Seems pretty decent to me...10% variation is acceptable when it comes to comp tests...so looking at those results the variation is within acceptable limits...who did the comp test? Did you test 4 & 6 again to make sure those readings were consistant? Sometimes you might not get a proper seal when you screw the gauge in and that gives lower readings...
Why do you say the results are high? Rb25s have slightly higher comp ratios so that seems fine as well...
Edited by limpus
A wet test usually will give higher results...it seems that all the cylinders have given a higher comp reading in this case...cylinder 4 seems to have a slightly higher result which might indicate alittle more ring wear than the other cylinders...but defninitely not enough to be of concern in my opinion...i was always told that anything around 30-40psi increase (depending on the test gauge) is normal for a wet test on a relatively healthy engine...i could be wrong though...i guess you have to remember that it is a used car after all...and since you said its a 98 model means that its about 9 years old...rings will wear eventually...good luck...
thanks for the info.
Hoping to find something a bit healthier i think.
I mean my car i just sold has 120,000km and when tested had 160 + 1 or 2 right across.
And the wet test jumped evenly up to 170 - 180 Across from memory.
And that was 14 Years Old.
Anymore opinions would be good.
regards,
Tours.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
