Nissan Genuine Part Numbers
arbess
  • 3 weeks later...
Can i please get the part number for a 1991 r32 gtr clutch pivot ball as nissan sent me the wrong one. Its from a push type clutch. And how many different types there are. i really need to know. Thanks much appreciated.
Part No. 30537-40P00. Only seem to be one option for a RB26 engine in a R32
part number for wheel studs to suit a r34 gtt? let me know if u need more details and i will grab them, would think that they would all be the same tho!
im looking for the part number / numbers for a R34 RB25DET neo Auto ECU.
I have some of my number but part of the sticker has been ripped off.
atm i have
07
23740 AA510
A56**3 J02 8520
Someone Iv been looking for :rant:
Have you got the part number for rb20det, 1993, r32 skyline. Iv been tryying to find pressure plate bolts but cant seem to get them off Nissan because my car is auto and doesnt have these bolts so they cant find them :D Doing a manual conversion.
but i need:
Pressure Plate Bolts
Airflow meter plug (if there is one?)
Thanks
  • 4 weeks later...
  • 3 weeks later...
  • 5 weeks later...
Hi Guys
I need a part number for an Injector Loom/Harness for an RB26DETT from an 89 R32 GTR
Went to order one from nissan but got given a coilpack loom instead
any takers
thanks
-D
Well it's a horrible diagram with horrible descriptions... but it looks like they probably ordered you a 24079-05U00.
That leaves you with a 24077-05U20 Harness Assy-Engine or a 24079-05U01 Harness Assy-EGI Sub.
thanks simon
we'll see what they have to say - the 24079 is what they ordered me originally which turned out to be the coilpack loom
-D
Yeah it's pretty obvious that 24079 is a coil pack loom... but it's a bit trickier to tell the other two apart.
it looks like the injector loom is part of the main loom that comes from the ecu ;\
-D
    • Which injectors are you using? It's likely the fuelling is off also, so as above.
    • Awesome to know. I have a Series 1, and When pulling my front bumper off for the first time i realised my reo/crash bar was a bit worse for wear, and was going to try pick up a better one soon just so i can replace it. Someone is selling a full series 2 front bar and brackets for a decent price, so was going to probably reuse my brackets and install the new second hand reo/crash bar. I also have a genuine Altia body kit to do up, spray and put on, and not sure if that will use the series 1 or series 2 brackets for the front bumper, so having both will be handy, and knowing i can drill holes out to make stuff fit between series is also handy to know!
    • I should also say that the while they are different the only parts that matter are the center headlight supports and center bar from S1 to S2. The center bar will work, but the S1 has holes that clips go through into the S1 bumper. So if you were super cheap you could simply drill the S2 bar. Same thing with the side/wings. They have slightly different 'clips' but can be made to work. The center headlight brackets however, cannot. This is also where the GTR differs, which has a different center bar, and different headlight supports (to either GTT system), it also has different 'wing' headlight supports which is what I am calling under the headlight. However those CAN be made to work with the GTT Reo for a GTR front bar by a small spacer and a drill/tapping a thread into the reo because the bolt positions are slightly different. So people only really need the center brackets to go between GTT S1, GTT S2, and GTR if you are happy to do some tinkering.
    • Indeed  😃  Appears the site is back up now (migrated not updated) - kudos @funkymonkey & @PranK
    • If this, then this You can't really get away without it. There are hacks that you can do in Nistune, but things are much easier with the sensor than without it. If you're not planning to Nistune the ECU, then stop right now and add it to your plan anyway, because the ECU is going to shit the bed over the missing ABS and TC computers that it expects to see, and you need Nistune to stop it chucking all its toys over the side of the crib.
