Hi guys,
organising a group buy for HIDs, here's details from supplier:
Brand new 12V 35W single beam bulb type HID Xenon Light Conversion Kit. This is a genuine HID kit that is ADR Approved. All our products have been individually tested before packing, and it is Plug & Play. 30-40 min. to install, no modifications needed. All hardware included. Comes with 12 months warranty.
Package includes
2 x High Quality Xenon HID Bulb
2 x Water-Resistant HID Ballast with Built-In Igniter
2 x Secure Mounting Ballast Bracket
2 x Wiring Harness with Quick-Disconnects
2 x Screw & Washer Set
1 x Illustrated Installation Instructions
Available Bulb Sizes
H1, H3, H4, H4-2, H7, H8, H9, H10, H11, H13, 9004, 9005 (HB3), 9006 (HB4), 9007 (HB5), 880, 881
Available Color Temperatures
4300K 6000K 8000K 10000K 12000K
The pricing I can get atm is:
$270 delivered if 1 - 5 people interested
$250 delivered if 5 - 10 people interested
$230 delivered if 10+ people
yes, these are made in China, don't expect too much for this price... but they are good quality, my friend's got one installed in his 2007 X-trail, we already have 2 ppl interested atm, including myself.
The kit comes with 1 year warranty and you will get free parker bulbs ~~ the pics are of the kit, different bulbs available and the nefore and after HID conversion pic on friend's car.
cheers
1. -
2. SKY 34
3. cln
4. Aeris
5.
6.
7.
8.
9.
10.
Supplier is a friends friend working with bunnings. And stops until we have about 5 people interested, basically just trying to get cheaper price for myself.
https://www.sau.com.au/forums/topic/173027-jm-hid/
don't need to drill holes man, just replace the bulb and connect to the ballast.
you can mount the ballst some place else use Velcro or sumthing, or if you want you can secure at existing bolt holes
https://www.sau.com.au/forums/topic/173027-jm-hid/#findComment-3182417
  • 1 month later...
Guest
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
