  • Replies 71
Hi guys, For ceramic coating when the dump pipe is already on car, remove dump pipe, 1 hour, new gasket top and bottom, send away 3 days, spend $200, no car 5 days, replace dump pipe 1 hour.
Not for me, I rather spend $60 on wrap and do it all in less than an hour.
nothing against thermal coating, heat wrap done right works just as well. It's cheaper, easy and doesn't see your car off the road.
The rumours about thermal tape is basically due to people who don't install it properly. I have done this to many a car and the only issue I ever had was on cheap mild steel and I had not followed the instructions (first effort).
Other than the one bad experience I have had trouble free operation on several installs over many years.
Instructions:
* clean surface
* spray with ceramic based exhaust paint (VHT flameproof mat white)
* Cure the paint as per instructions
* Wrap pipe 'evenly' (very important -- and why DEI is great stuff).
Most ceramic coating I have encountered is less effective than heat wrap. I can put my hand on the dump pipe , when it's probably glowing red with heat wrap. Most coating doesn't trap this much heat. The stuff that does isn't cheap.
The price varies for coatings. The most insulative coating is very expensive. Simply ask whether you can hold the dump pipe with your hand when its on the dyno pulling a full power/boost run. If the answer is 'yep, you can feel nothing' then the coating is the good one, if not don't bother wasting your money.
In Brisbane the place to go is Insulation Supplies, 330 Curtin Ave (west) Eagle Farm. 07 3268 7399. They are specialists in insulating materials. I'm sure there will be an equivalent place in all the cities. They also have 10mm foam sheet with aluminium facing one side, self adhesive the other, I used a double lthickness of this to make my cold air box and it is very very effective.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
