  • Replies 78
Ok So its on this wensday night? ive been a few times with my dads mates watchin them run there cars but never actuly gone for a run ? whats the price and what do i need to bring apart from my car helm and some balls. :D
https://www.sau.com.au/forums/topic/173135-wsid/#findComment-3184580
Hmmm might consider going down this week, gonna strip out the passenger and rear seats and see if it makes much difference.
might get off my ass and fit the oil cooler and change the oil to get ready for SAU trackday.. man.. so lazy..
https://www.sau.com.au/forums/topic/173135-wsid/#findComment-3184864
hey ray,
i dont think im ever going to go to those lengths....way too lazy to take out the seats just to put them back...
u heading out to wakefield? u racing? im heading out in sept so i thought to give this one a miss....
have u seen what i did to those T1r's? had a little fun on them....regretted it almost instantly...
https://www.sau.com.au/forums/topic/173135-wsid/#findComment-3184978
Yep SUPPORT SAU and heading out to Wakefield on July 8th or 9th can't remember.
Yeah... kind of tight on cash these days wanna see how close to 12 flat i can get with the current setup resorting to all measures without breaking anything haha
then camshafts will go in and get me a HIGh HIGH 11 hopefully but we will see..
taking advantage of the weighing bridge at WSID :thumbsup: last time the whale weighted in at 1376kg with 1/4 tank of fuel full interior less spare tyre/jack/tools.
LOL i read about your T1R's and SKidpans days. i saw it coming good work rofl
https://www.sau.com.au/forums/topic/173135-wsid/#findComment-3185436
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
