1995 R33 Gts-t M-type
108,000k's
Complied and Registered
White
Sunroof
Tinted Windows
HKS 3037S Turbo
HKS External Wastegate
HKS Stainless Steel Manifold
HKS Triple Plate Clutch
HKS 272' Cams
TRUST Plenumn
HKS 6x740cc Injectors
Huge Fuel Pump
Custom Fuel Rail
80mm throttle body
HKS F-CON V Fuel & Ignition ECU
Custom G/force 600x300x100mm Intercooler
HKS Airpod on custom 100mm piping with airflow meter removed
Unknown Internals although almost definately forged pistons and toughened rods.
Line Locker
TRUST Profec A Boost Controller
TRUST Turbo Timer
TECHTOM IIC460 Drag Launch Controller
TRUST 60mm electronic Boost & Exhaust Temp. Warning Guages
Autometer Sport Comp Monster Tacho & Shift Light
Apexi N1 80mm Exhaust
HKS Front Pipe (Turbo to Cat)
Custom Stainless Dump Pipe
Cusco Oil Catch Can
Unkown Brand approx.. 90% Locking LSD
Veilside Shift Knob
Recaro Recliner Seat with Sabelt Harness
Potenza Suspension
Nismo 400R front bar (needs repair)
Different Skirts, Rear Bar and Drag Style rear wing
17x8 and 17x9" White 5 Spoke Wheels
Falken GRB FK451 245/45/ZR17 and 265/40/ZR17 tyres (brand new)
Slotted Front Brake Rotors and Aftermarket Brake Pads
Newly Rebuilt Gearbox with brand new internals
Built up by G/force http://www.gf-eng.co.jp/
15563669
15562702
15564018
If you are seriously interested email me or pm me. POA. Lots more photos available upon request.
Email: [email protected]
https://www.sau.com.au/forums/topic/17335-heavily-modified-95-r33-gts-t-m-type/
Thanx Dragon
haven't had it tuned in australia yet.... waiting for croydon racing development 2 get tha software.... jim said he'd have it in a few weeks.
To give you a rough idea similiarly modified gts25t's i have seen putting out about 300rwkw at 1.2bar of boost. With a dyno tune i am sure this would match or pass that figure on 98 octane pump fuel.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
