ok, ive read about the automatic increase with boost when you change your exhaust from the standard one.
If someone has changed their standard exhaust from the cat back i would assume boost would slightly change.
would the boost change much again by replacing dump/front pipes?
definetly notice more midrange. when i got my exhaust done, the cat back arrived first, then about 3 weeks later the front pipe and the dump - you'll notice the difference. You will lose a bit of low end (barely noticeable), but the responsiveness and top end breathing is much better.
And of course only for off street use, decat it and throw flames!
the boost increases due to the drop in the back pressure. read this from somewhere a few years ago, something bout physics and air wanting to flow from a high pressure area to a low pressure area.
therefore, when u lower ur back pressure, more air wants to go from the compressed, high pressure area, to the low pressure area, and thus ur boost rises automatically.
Ronin.. you must help those of us out that get busted..hahaha
I have a cat back system, but running a silencer which keeps it nice and quiet. I know i'm not making the most out of the system, but would this still flow better than stock?
Cheers,
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
