still get a day out driven yr car how ur not allowed to on the street....ive been to the first 2 and never used the hand brake...give it a crack....im sure u will have a blast!!
  • Replies 79
Hey guys,
Considering doing one of these in my V35, but the question i have is, is it worth it on an auto?
My other problem is that there is no handbrake, but a foot park brake instead.
Any thoughts?
I've seen a couple of guys go out and do this day in an auto. You shouldn't have a problem just stick in the lower gears.
I have noticed alot of people, including me don't use the hand break. There is a neater way to get around to not using it and Boz and the boys can show you either way.
Cheers,
Corinne
it was fun, i need pics and videos 2. still waiting from the first one ofr pics lol.
there is one set of pics up already over on autosprts website, but we should put some on here as i will find it easier :P
awesome awesome fun
Huh...what a blast....great time....I kick started the list for Skidpan #4. C'mon guys no liner won so far....we need more skylines...getting there. I can not believe that a Z4 beat everyone!!!!!
Eug.
Eug.
The Z4? your kidding.Even tho i didnt partake in the activities it was great to poke fun at the silvia drivers (wannabe drifters) it seems if they see it on TV then they must be able to do it themselves.
Eug. Great to see your car up close. Pumping 300kw out of a 2835 at 1 bar is awesome.Will definately be out there for the next one.
Hurry up and organize the next one Corrine :P
That was awesome fun. didn't think a rebuilt a rebuilt diff would help some much. So much better than lighting up the inside wheel.
Thanks again Eugine for letting me have a go of your car and sorry about busting the belt buckle, I do get a little excited in a powerful car lol.
I almost won the shootout but i did win turbo rear wheel drive class by a decent amount and i think i will be going to number four to. i have a little bit of footage from the day but not much of anybody but me and my mate in the white 180.
craig did u end up going?
how was it?
yep.
was a blast.i think next time though i will go out with some decent sized rubber on the rear.i had the stockers on.good to get the tail out and keep it there on the limit but not so good if you are after times..the funny thing was,that i never new that every stage was going to be timed untill i got there..good times..
i liked the shoot out at the end of the day.was definantly a highlight of the day.
you broke the belt buckle.poor eugene.see why i never let you drive mine..nah just kidding.im a bit paranoid when it comes to other people driving my car josh.they have crashed it before.and it is allways in the back of my mind.you should have heard your gf giving you props on your "accidental slideing" out on the road when in the wet.she says you hold it like a pro.hehe.
i might come out of retirement for this one....the first skidpan day this year was dominated by skylines, the top 3 rwd turbo were skyline, 2 r33 S2, one R33 4 door. I took out the class.....
but im in the AWD class now, gotta mix it with the big boys....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
