The other day i noticed that i had a dent made by someones doors on the left rear panel. I share a driveway with a neighbour and i noticed that they also have a chip on the edge of their right hand side rear door on the rear of their new calais.
I approached them and they said it could have been the kids but now say it couldn't have been them and say proove it was us.
What can i do? Should i just call my insurance company and let them deal with it?
I have been quoted $700 to fix it because the whole panel needs painting. Is this a good price or can i get it done cheaper? The dent is right on the sharp line that runs across the side of the r33.
Edited by BillyMako
https://www.sau.com.au/forums/topic/173414-dent/
try a paintless dent removal company, will m ore than likely be cheaper
Yeah they do some pretty good work as well.
Id start with a mobile dent doctor and go from there, the new company that is around now get good results without having to repaint panels :(
https://www.sau.com.au/forums/topic/173414-dent/#findComment-3189968
It's pretty noticeable in real life. I dont think a dent doctor would get it out. It needs painting also. Will i have much luck getting my insurance company to take care of them?
a dent doctor will make it look a whoooole lot better and after they are done it might only need a touch up with paint and end up been alot cheaper.
https://www.sau.com.au/forums/topic/173414-dent/#findComment-3190749
just try and raise the $$$$$ ur self and leave the insurance out thay will jack ur payments up those basterds alll ways tryin 2 screw the little guys and thay will not be able. To Prove it so my thing will be try and raise the $$ and let the insurance out of it!
The Door idea is a nice idea as well but belive in karma man :closedeyes:
https://www.sau.com.au/forums/topic/173414-dent/#findComment-3191393
i have used a dent doctor in anotrher car and also ensured they do paint touch ups, came out looking Perfect!!! Cost me about 160. i used him about 3 times and he got used to me calling him :-) The worst one i did was worse than that and made a much bigger gash, so he filled it over with a small amount of bog, matched the paint code, touched it up, but clear over it and bobs your mothers brother........
https://www.sau.com.au/forums/topic/173414-dent/#findComment-3192065
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
