hey guys i have a heap of parts up for grabs:
reason for selling: building an rb26/30 no longer need rb20 stuff smile.gif
S13 Rear Bar red $50
R32 Door Trims $50 for both
S13 Dash $100 Good condition
S13 Instrument Cluster $100
S13 Digital Climate Control $100 with loom
stock 20 turbo Good Condition $100 (HAVE 2)
manifolds to suit rb20 or 25 $100(have 2)
Complete RB20det block $300 (hasnt been pulled apart in good condition)
Very Good Condition RB20det head $200 (comes with all cams, cam shafts)
Rb20det Manual ECU $100
Rb20det Air Flow Meter $80 (green sticker)
hicas power steering pump $60
Rb20det alternator $100
ac compressor $offer
RB20det short shifter never used $100
Stock RB Coolers and piping $50 each
stock flywheel (needs machine) $SOLD
Stock r200 dif $80 (non lsd)
Contact: please pm me with wot u want/need i tell ya if i have
Edited by Mayo
https://www.sau.com.au/forums/topic/173819-rbr32s13-parts/
yep, Also now have a complete running RB20det for sale, $900 still in car can show running, car is never driven as not registered andhave no license, i can pull out in a few hours and have ready upon a deposit
https://www.sau.com.au/forums/topic/173819-rbr32s13-parts/#findComment-3196784
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
