Ah well, it's on ebay now: http://cgi.ebay.com.au/Nissan-import-HR31-...1QQcmdZViewItem
Time to move on.
says the man who had a similar painted 2door HR31 :)
lol @ you two. I'll never sell up... i couldnt afford to :)
I wanna see the new car soon!
LOL sky^rkt, moving to euro "goodness" but still going for jap power!
In terms of mods, probably a few simple things...dump and front pipe to make the exhaust 3" all the way, up the boost a tad and SAFC. 190 - 200rwkw should keep me happy for a while :dry:
awesome looking 34, where abouts u from?
I'm in the s.e 'burbs.
I'm pretty sure I've driven past your supra on Westall road before, that thing is mega low. :P
Recieved my SAU stickers in the mail yesterday, (thanks Kaz) so give us a wave if you see me on the road :D
Does anyone know where I can get the URL style stickers from? General meeting perhaps? I want one for the rear window...
Also I've purchased some speakers for the front doors and rear parcel shelf, is there a "how to" guide to remove the door trims on a GT-T? Is it easy enough to do? I tried a search, I came across a lot of useful information but not for the R34 ;)
Cheers
Anth
PS: Oh, and the 31 is still for sale for anyone interested:
http://cgi.ebay.com.au/Nissan-RB20-HR31-R3...1QQcmdZViewItem
Relisted on ebay, no reserve. It needs to sell on Sunday before dad throws it out of the garage :nyaanyaa:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
