I have just got a used set of front - HKS Hyper D - coil overs, and I can't seem to find any data on them other than in Japanese :(
Does anyone have anything on these? Or know where I can look please?
I keep reading that they are 16 way adjustable.... OK... so I immediatley fail HKS Hyper D 101 as the only adjustments I can see are the Nitrogen Valve (any idea what pressure range??? and how to decide) and of course the spring height...
So anything would be great.
Cheers
https://www.sau.com.au/forums/topic/174291-hks-hyper-d-settings/
Cheers
well mate i have a set of HKS hipermax Pros ,mine are damper and height adj and also have the valve outlet-air or nitrogen i guess? my sping rates are 10kg rear and 8 front frm memory or maybe other way round??? but i havent installed them yet, and i dont have any more info for u or i to go on not even sure if they are the same coilovers- post a pic up and i'll compare them, hope its some helpo to u, cheers Damo
Edited by madaz R33
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
