  • Replies 78
Posted Images
for the past month or two i have been getting 260kms to a tank! lol. had a new turbo on and it was running rich then, turbo decided to shit itself and so stocky is back on, havent been for a tune cuz im saving money to rebuild the turbo and then get it tuned. i go through a full tank every 4 days lol
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/4/#findComment-3283396
Thought id update and say 750km from 1 tank!!! (was all highway, but still) Guess Skylines can be daily drivers if you live out in the country :(
750????? :D
You sure you were'nt in a barina dreaming of a skyline :bunny:
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/4/#findComment-3305512
Thought id update and say 750km from 1 tank!!! (was all highway, but still) Guess Skylines can be daily drivers if you live out in the country :bunny:
Lets see if I can convince my dad to get a r34 to replace his toyota camry I4 2.2 (does around 600km a tank)
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/4/#findComment-3305571
i thought myne was pretty thirsty but looks about right. a full tank on myne lasts between 350-400km/tank But i drive a mixed of spirited driving and crusing on the highway. I very rarely get above 400km. only once and that was from canb to syd of which i nearly reached 500km. Alot of the first posts seemed to state they were getting close to 500km's on a tank from a r33. Weird... maybe the fuel has changed or something?
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/4/#findComment-3311150
I just dont think people are calculating their fuel usage properly..
they assume that E on the gauge means its empty..
If i went by my fuel gauge id be filling up every 250-300 kms
but i get closer to 450 from a tank of pure suburb driving
remember..
fill fuel tank to the top
reset trip
drive drive drive
fill fuel to top again..
Divide the litres of fuel you put in by your trip meter.. eg
42l/ 298kms = 0.140939
in other words.. 14.09l/per 100kms
Edited by MotoMan
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/4/#findComment-3311575
R33 GTS-t running 230-240rwkw on low boost.
I get about 200-220km/s per tank which i think is apalling despite not much of it being freeway driving.
I'm gonna get it re-tuned as my tuner says thats the problem. might get the O2 sensor checked also.
When it was stock i was only getting around 300km's to a tank also.
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/4/#findComment-3314001
I'd say it is the tune.
Mine is making 268rwkw on 15.5psi with a GT30 and has just returned 410km's to a tank (50litres) and that was with a heavy foot as you do when its just been tuned and you want to see what it goes like. :laugh:
I have the o2 sensor turned off.
Its running the RB26 base ignition map and hasn't had the ignition tweaked for light load/cruise (load points 12+ have only been tweaked)
Its running 15:1 up to load point 12 where it runs 13:1 during boost build.
So only fuel has been tweaked; no ignition and its returning fairly decent economy considering how it has been driven.
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/4/#findComment-3314189
remember..
reset trip
drive drive drive
Exactly what I was going to say too... To all these people posting "350km per tank" etc -- this is a completely inaccurate measurement because no-one runs their tank to empty so therefore every persons measurement (ie. "per tank") is a different size!! :)
As above, work out your L/per 100km usage as this is the only accurate measurement of fuel usage!
Oh yeah... I get about 380-400km per tank :)
My last fill was 47.69L divided by 380km = 12.5L/100km - Normal suburban driving
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/4/#findComment-3324706
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
