Ok today i finally got my new GReddy Profec B II boost controller... and it has been installed as per instructions... but we are having a few issues...
Now previously i had a Turbosmart Boost controller which was only giving 10psi and we couldnt get anymore then that from it...
After installing it.. we started driving it around back streets and pulled 11psi in 1st and 14psi in 2nd.... which is great as really goes much better now...
Now heres the problem.... in 3rd...4th and 5th gear... it starts to hit boost at 3200rpm... but as soon as it hits 3900rpm... the boost disappears... We tried this a couple of times and eventually found that always at 3900rpmish it will disappear then reappear at 4600rpm... like a BIG DEAD SPOT.
This onyl happens in 3rd 4th 5th gears... not 2nd or 1st as these are perfect... So my question is... has anyone encountered this problem before...
Could it possibly be that the wastegate is shutting on me for some reason at a certain rpm.... ... Also.. it never happened on the previous boost controller.... though it never had more then 10psi.... But when i dont spool over 9psi it seems to work fine....(i think)
Any solutions to maybe keeping the wastegate open if it is shutting??
https://www.sau.com.au/forums/topic/174309-boost-issuesflat-spot-in-high-rpms/
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
