  • Replies 951
I have the week before off so Winton is an option. Would rather not drive down alone so assuming I can get at least a passenger I think I'd like to get down a day early and learn the track secrets of the Vic boys. If they get me running faster maybe I'll defect to Team Wang
I know this is still some time off but I vote for a very, very early morning start. If some of the guy/gals from north need a place to crash the night before, we have space.
i'm considering going down early aswell for the track day, have to confirm a couple fo things, but 75% sure atm, i'd be up for meeting up and going down.
LOL. I'm just hangin' around seeing what crap you fools are talking up. *Runs and hides before flaming starts.
Right you are getting two boxes of tissues :laughing-smiley-014: looking forward to going into battle
well I know I will lose but atleast ill have fun doing it.
This is a fantastic effort for NSW people and please tell people that we are more then happy to get spectators down too it is a fantast weekend
Where did you guys meet up at last time?
we met in a carpark 2mins from the intersection with king georges road (which you would come down to get there) and the M5 in beverly hills.
i assume its going to be the same place again??? will we fit there???
:/ Hmmmm Jess.... Andrew.... can I sleep on your beanbags on the Thursday night before puhlease! Otherwise it will be a 5am wakeup call for the 8am meetup!
they have a spare queen size bed you know...
but apparently thats mine :(
cause im too lazy to get up the extra 10 minutes earlier :thumbsup:
So it sounds like a few of us (Steveo/Sam/me) might make it down to Winton for a track day on Friday. I'm up for a very early departure (5AM?) to beat traffic. Like to get there and chill for a bit.
Scotsman - it there a place to crash near Winton on Thursday night or should we book into the cabins a night early?
For those of you who are new - this F'N rocks. It don't get much funner. Of course we will have to start dominating the Mexicans...
NSW TFW
I'm interested in this morbit fascination you seem to have with tissues...
Tell you what! SAUVIC will organise a tour of the Kleenex factory in Shep for ya.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
