  • Replies 951
Oh no.. sounds like everyone is going down the Thurs or Wed..... anyone leaving the Friday morning????? :ninja:
Yep... work denied me the extra time off as its too close to month end :ninja:
Il be leaving Friday morning after all............
Of course it is!!
Me and Doof are going down Friday morning same as Smoky and Andrew!
Hmm this might change accomodation arrangements :ninja:
how does it change it? more $$$$... less peeps??? iono????
Well i am definatley heading down Friday morning... are we still meeting at the spot off M5 or since Steve (N1GTR) is going Thursday or sumsing..., we can meet more local... ie Chatswood or somewhere around there? Means can head straight thru.... just a thought....
Only changes for the peeps staying 3 nights :ninja: I think...will know closer to the date
Hmmm could do!!!
Oh oh, I need somewhere to stay!
Anyone want me to share a bed with them... im real warm! :ninja:
You have a bed!!!..... *winks*
We need to book another cabin the 3 I have booked are all full!!
So who is left with out a bed???
Shaun
Steveo
Jen (Tripin)
Oh no.. sounds like everyone is going down the Thurs or Wed..... anyone leaving the Friday morning????? :D
Next post was..
meeeeeeeeeeee! I am.
I'll just enter a address in the GPS and it wil take me there 1000hrs later lol
Sorry if it wasn't clear. :ninja:
Where can I meet everyone else? :ninja:
Vic - is there a servo or something on the Hume Hwy we can meet you at? Dunno organise something closer to the time...
Oh and is everyone taking CB's??? I know i am and want a fellow CB whore :ninja:
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
