  • Replies 951
Oh no.. sounds like everyone is going down the Thurs or Wed..... anyone leaving the Friday morning????? :ninja:
Yep... work denied me the extra time off as its too close to month end :ninja:
Il be leaving Friday morning after all............
Of course it is!!
Me and Doof are going down Friday morning same as Smoky and Andrew!
Hmm this might change accomodation arrangements :ninja:
how does it change it? more $$$$... less peeps??? iono????
Well i am definatley heading down Friday morning... are we still meeting at the spot off M5 or since Steve (N1GTR) is going Thursday or sumsing..., we can meet more local... ie Chatswood or somewhere around there? Means can head straight thru.... just a thought....
Only changes for the peeps staying 3 nights :ninja: I think...will know closer to the date
Hmmm could do!!!
Oh oh, I need somewhere to stay!
Anyone want me to share a bed with them... im real warm! :ninja:
You have a bed!!!..... *winks*
We need to book another cabin the 3 I have booked are all full!!
So who is left with out a bed???
Shaun
Steveo
Jen (Tripin)
Oh no.. sounds like everyone is going down the Thurs or Wed..... anyone leaving the Friday morning????? :D
Next post was..
meeeeeeeeeeee! I am.
I'll just enter a address in the GPS and it wil take me there 1000hrs later lol
Sorry if it wasn't clear. :ninja:
Where can I meet everyone else? :ninja:
Vic - is there a servo or something on the Hume Hwy we can meet you at? Dunno organise something closer to the time...
Oh and is everyone taking CB's??? I know i am and want a fellow CB whore :ninja:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
