  • Replies 951
The good news is I'm staying up for the Sat night this time.
Good thing Snowy!!.. not like last time where you and James had to report to the ice cream truck!! :D someone call Mr. Whippy??!! :D
I will borrow one off Chubbs unless smokenhowzen has one.
Borrow what Andrew?? :D
ok i'm thinking about going down on the thursday to do winton on the friday and watch deca. if someone could pm me the details about accomidation etc that would be great
thanks mitch
1) I'm keen to get an early start on Thursday - like really, really early. I know a couple of you might need to drive down to Sydney and am happy for anyone to crash at my house Wednesday night if it helps.
2) There is a Shell near my house in Neutral Bay that sells Shell V Racing (100 Ron). If you really want that last little edge perhaps we can get gerry cans and see if we can get a few to travel down on Brad's trailer. I run it all the time and it is good stuff.
3) Having done this drive before, I know how nice it was to have a navigator/passeneger (The big A rode there and back with me - we both survived the experience). If anyone wants a ride down and back just to check it out, let me know.
thanks mitch
bump
so can anyone tell me? would really like to do this.
Guys...
Ok I am confused....
Is anyone heading down just on the friday?
Too spaced out to read other posts!!!
Otherwise the mrs and Iwill have a nice social drive ourselves!
Guys...
Yep. a few of us are....
Jess, Andrew, myself, ummmmm, Wayne, Kasey..... ummmm think there is more!
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
