  • Replies 951
that site doesn't really tell us what we're after
anyhow.. i just called them... Friday 24th August is the National Circuit. It'll be $120 and you'll need all the usual stuff (considering you need fire extinguishers etc for deca i didn't ask about this)... Gates open at 8am, racing starts about 10am and goes until 4:30. 30min sessions.
Thanks Liz thats the answer i was after ;)
lol.. there is a corner called roll over corner.
look out ando lol
I believe your the one who has 'offs' :nyaanyaa:
Ando you are gay
I have told you Andrew... i wont turn gay for you!!!! :glare:
yup.. that's right
stacks of stacks.
So lizzeh... case of beer on Winton :sorcerer:
Round 1 Battle - R33 GTSt vs Cefiro - Ando winneh!!!
Round 2 Battle - 180sx vs Cefiro - who will win, only time will tell :(:)
Yeah me too...I want some :(
Oh ive got some, i just wanted to know what exactly theyre on :wub:
Round 2 battle - this time 180sx vs Cefiro - who will win, only time will tell :(:)
Oh yeah, big bet time - bring it on biatches!!!!
of course!!!!!
bare in mind.. when you were drunk on thursday night you said you'd buy me 3 cases if I beat your time this weekend. lol.... I'm prepared to downgrade it to one. lol.
of course!!!!!
Me .. drunk... never..... but yeah i am happy to honour that deal... go better than 1:58 @ E/C and i will buy you a case of beer!!!! :(
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
