Selling for a friend a Silvia Spec R,
The car is in an import from japan and is priced for quick sell:
Pearl white
28000kms
turbo back exhaust
fully adjustable suspension
Blitz Pod filter
The car is in brand new condition.
Price: 32000ono
https://www.sau.com.au/forums/topic/17438-2000-model-silvia-jap-spec/
