the other week queensland finaly got some rain and my car ran like crap, so i put the stock air box on and it was ok after a while. this weekend again, rain, car ran crap, but now that the rain is gone it still sounds like not all cylinders are fireing properly (my RB sounds like a subaru), My cousin said it sounds like maybe my plugs are gone (copper plugs changed 1 or 2 months ago when tuned) or my coils are shagged. does it sound like it would be my coils plugs AFM or something else.
-AIF
https://www.sau.com.au/forums/topic/174471-rb25det-running-bad/
-AIF
Have you got vents in your bonnet?
man i had similar thing happen during the rain.. idle seemed to fluctuate arround 750 rpm instead of the normal 650 rpm.. I too using copper plugs which have down about 5000 - 7000 k's (first time ive used coppers in my skyline) migth just be coincedence ???
no vents on the bonnet, but the machanic that came out to check it out said he could hear the spark escaping and that it was shitty coils, and that they may have worked fine when it was dry but as soon as any kind of moisture was in the air BAM, i'd loose spark.
so im just waiting for my splitfire coils
yay
AIF
yay
AIF
yeah dude will prob be your coil packs, wen it rains air gets bit colder and will mis-fire and carry on cause spark is escaping. try pullin coil packs off and wrapping some heat resistent electrical tape round em, if that helps it time for a new set of spit fires coils!
cheers
thanks for your replies guys, i got a set of split fires from SLIDE and when i was installing them i found that there was close to half a f%*king cup of water drowning the coil packs and s/plugs,
yeah i know what your thinking. (WTF)
where i live i park in a rather steep driveway and when it rain for a few days tyhe water ran down my car and flowed over the part where the wipers are, into thew engine bay and into through the coil cover,
i should have taken some pics for you guys, the water finished just below the bracket that u screw the coils into, between the 2 cases.
thanks again,
Aif
sounds like your getting water into your intake. i have had that on my car when i go through big puddles. i have a hole under the pod filter where i think the stock intercooler went, and the water heads up through there into the air filter. makes the car run like s**t for a while.
I think if you had bothered reading the thread you would have realised he figured out what the problem was
either way good to hear its fixed
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
