Is the groove direction on the Grex brake upgrade rotors (6pot front, 4pot rears) the same front and rear? If so, which direction do the grooves run? I have had the brakes installed but the front grooves lay back and the rear grooves lay forwards. And this is how the brakes are stamped left and right.
Thanks.
https://www.sau.com.au/forums/topic/174650-grex-brake-rotor-direction/
(from memory the grex 6 pot set on the supra had l or r on the rotor or an arrow) and ours cut from out to in..... i will ring trust (and open the box of gtr ones i have in the warehouse) now maybe the pics above off the site are for demo only..... the pics in the GREDDY book face out to in... opposite from the website :P talk about confusing.
the best way to check as many brands are differrent is by looking at the internal cooling grooves in the rotor some are unidirectional some are not.
brembo sweep out to in.
OK this is the official G-O from the GREX dude at Trust;
Greddy swapped rotor designs not long ago so some kits include reverse rotation rotors and normal rotation (not side to side but differrent rotation set front to back). As i mentioned earlier all the rotors are marked L or R (some have a L or R as the last didgit in the part number on the rotor bell) The internal design designates L or R so best bet is to check the rotors and run them as marked.
ok put aside all the business of wich way the slot is facing.
you need to install them so the internal vanes are laying back. like <--------- rotor direction, vanes = /////////// so the inside of the disc sucks the air from the inside of the diisc. but you would know as your buying an alcon brake package and have some idea on brakes :thumbsup:
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
