Hi,
I'm selling this gear for a mate. Its last years model, but in excellent condition. I believe he is offering a good deal, authentic and genuine.
Email me for any pictures.
Alpine CDA-7876DA Deck + Alpine CDA-7876da 12 Disc Stacker for $1000 firm.
Sony 10 Disc Stacker CDX-91 with custom file (cd naming) for $250 ono.
Details:
Product Specifications
Motorized face, Detatchable
8x Oversampling
CD Text, CD Text Display, CD Text Scroll
CD-R Compatibility
3-Color Display with Spectrum Analyzer
XM Satellite Radio Ready
Swing Face Mechanism
Versatile Link Ready
Ai-Talk Display
Anti-Theft Detachable Front Panel
Detachable Trim Plate
Dual Illumination Buttons (Green/Amber)
BBE Source/Memory
Bass Engine Plus
External Processor Preset Function Recall
3-Position HP/LP Crossover (12dB/Oct.)
Subwoofer Level Control
Subwoofer Phase Control
(3) Preouts
4V Subwoofer Preout
Audio Interrupt In
Clock
Fader & Balance Controls
Gold-Plated RCA Connectors
Loudness Control
Rotary Encoder Volume Knob
S.T.M.(Source Tone Memory)
Selectable Fader
Sound Guide
Wireless Remote Control Included
Pictures are available below:
http://www.iinet.net.au/~happyg/DSCF0005.AVI
http://www.iinet.net.au/~happyg/DSCF0001.JPG
Surely you boys with you're mean cars, must want a mean stereo. You can't get a better price for the top of the range alpine deck.
PS: I have a cool movie of it working. Face folding down and the pretty graphic EQ
  • 1 month later...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
