Hi.
I have a sump fra a R33 GTS4, (or something) Its from a RB25DET s1 engine woth 4wd. Only bought the engine because i needed tha valves. was cheapest this way. Question is, is that sump anything worth? It looks in good condition.
Best Regards
Ronni
https://www.sau.com.au/forums/topic/174835-sump-from-a-r33-gts4/
Hi.
Best Regards
Ronni
same sump as a gtr im pretty sure(well my stagea 4wd rb25 sump was), usually worth around $300 or so, depending on if u got the diff in it aswell. they have 4.3 gears i think which a few gtr owners are chasing.
