I'm just doing a bit of a cleanup and selling off some stuff. Everything is in very good condition and 100% in working order. I am selling all this stuff as its all come out of a previous car that i just sold and i can no longer make any good use out of it.
The following items are listed for sale:
MAKE ME AN OFFER! EVERYTHING NEEDS TO GO!
Headunit (sony CDX M630 - i think thats what it is), its got a graphic display and flips around so you can press the buttons and stuff, bit hard to explain. I'm sure if someone is intrested they could do a serach on it. Cost heaps when it came out - selling for $220, this unit retailed for $600 when it was on the market not long ago
--------------------PRICE DROP to $150----------------------------
Fog/marker lights: Brand new, bought in Japan, never used still in original packaging. I don’t like them so I am selling them.
PRICE ONLY : $30
HKS Mushroom Pod Filter with Adapter suitable to fit an R33 gtst skyline (not sure what other cars it would fit)
PRICE ONLY $40
---------------------------SOLD for $30------------------------------
12” Pioneer TS-W306C Subwoofer in box and inclusive of silver grill. I’m not sure about exact power output, but sound is very good as the box was designed by pioneer for that specific model sub. The grill is an extra which normally costs more. - $120, brand new this setup costs $250+
--------------------PRICE DROP to $90----------------------------
---------------------SOLD FOR $70----------------------------------
Single pocket din, universal, fits many cars - $20
---------------------SOLD---------------------------------
Response 2 x 80WRMS amplifier, current model, hardly used, has power control unit, very good value for money - $120
---------------------------SOLD for $100------------------------------
Response Crossovers : adjustable tweeter output: -3db, 0db, +3db - $20
----------- ----- SOLD for $10-------------------------------
Stinger Disribution block : brand new, paid $25 from JB – sell $15
------------------SOLD for $10---------------------------------
Gauge holder: brand new bought from Japan, not sure exact size (diameter 2.6 inches from a rough measurement with ruler) Im sure an average sized gauge would fit inside it. - $20
-----------------------SOLD fo $15--------------------------------
GRAB A BARGAIN!
PM me or call/msg me on 0413158822
Edited by PLR33
https://www.sau.com.au/forums/topic/174857-headunit-marker-lights-more-cheap/
  • 3 weeks later...
  • 4 weeks later...
  • 2 months later...
BUMP! throw me an offer! i will sell!
Dam..wish I would have seen this earlier.......
Did a search on Sony head units and did not get you..
Free bump...
  • 3 weeks later...
  • 3 weeks later...
