Given there is no car on the HPI drag list that comes close to that 60ft
and we are talking 8 second cars on street drag radials this seems very strange.
http://www.hpi.com.au/drag_records.php
There are cars doing 1.3's in the world but none on true street tyres that I know of !!
The all use drag radials and a good 1000 to 1500 hp !
I mean no offence but I think you gotta look at this logically.
If true this could be some sort of world record.
So let me get this correct Butters, you claim the car is 1000-1500rwhp and must be on drag radials at least? I think by the photo's we can clearly see they aren't any big flash drag slicks on there.
I will let RockoGTR come on here himself and maybe he has a couple of photo's that clearly show the car was on Nexen street tyres, just as it was sent over with. He will be putting slicks or drag radials on it next time, then hopefully the box will hold together and it should go quicker.
This car is DEFINITELY NOT 1000-1500rwhp either, it was nowhere near that.
I will let him no it might be a record and he can inform HPI and show his time slip and join the ranks :thumbsup:
Also bear in mind this car still has full interior and is a comfortable daily drive.
Edited by R31 Chick
I don't want to be taken out of context on my comment above so please allow me to clarify.
I think there is something being done differently to most every other GTR that goes to the drags in some department. Whether it's just a perfectly balanced launch from an outstanding driver or some tricky suspension settings, it's incredibly rare to see a 1.3x 60' time from any street GTR and it's especially rare for it to happen on streeters.
I'm not doubting the tyre choice at all when I say that I reckon there's more to it.
Great job though.
The car is extremely well set up from good suspension, good HKS exhaust, good turbo choice for the car, good tune, good driver etc. There is no NOS or any "secrets" on the car and I am sure Jeff would be happy to show anyone. We aren't trying to claim this figure from a stock car and we never mentioned suspension set ups etc... even tho the suspension isn't anything over the top or expensive. It doesn't have coil overs or anything.
There is no denying the figures, its just a very well set up car that anyone with any knowledge could build on what is not a huge budget.
As I am not the guru on the car or a mechanic I think between Jeff, NIB and RockoGTR they can answer all your questions. Pity they are all holidaying or away working.
Edited by R31 Chick
I don't mind being taken out of context ... seems to always happen on the net lol
R31 Chick you need to take this less personally, are you his girlfriend ?
I am sorry I believe with a 1.3 60ft if he puts on drag slicks he will not go stuff all quicker.
Did he manage to run another pass with a simular 60ft or is this a once off ?
I'd be keen to see it backed up at another track like willowbank If he does its quite an acheivement taking down the likes of keir wilson and theo woollett to the 60ft !!
He just sneaks into tenth place on HPI list, so well done on that !
Nope, I am his ex. Things do go out of context and being Steve's daughter I know this all too well. As my brother built the car is probably why I jump to its defence.
The car will be at Willow Bank soon. There is video footage of the car in rear wheel drive smoking 4th although Jeff hasn't sent it to me yet which will prove the tyre debate.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
