  • Replies 453
Posted Images
hey dude id be happy to be the last car in the convoy
sweet. you'll be my last man since you were first to reply. do you have a cb radio? if not, i got a spare. will be easy to communicate to you this way.
no worriess
dont have a CB radio atm but will be getting one by then its only like $50 but if i dont get a chance to get one by then, ill take you on that offer.
hello people
my name is peter
bought an r33 gtst few months back and i am keen to go on my first cruise!
put me down as a maybe, also my friend chris bought an r33 gtst2 last week and will prob come too.
hope we can tag along
Hey pplz, im new to this and i will be attending this cruise.
It will be my first cruise with my skyline which im really looking forward to it.
I may have a couple other mates coming along with their skylines asswell.
Looking forward to meet u all ppl. THANKS
no problems with having some new forum members tag along. your mates more than welcome to come too. hope to see you there.
thank you
cant wait it should be eaps a fun!
look forwad 2 seeing you there.
regards from pete
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
