im sooo pissed off, its my kids 4th birthday on the 9th. nothing i can do to get out of it or id be there for sure lol, cant bring him cuz his mum has already planed a whole heap of shit that day!!! :cheers:
  • Replies 453
Posted Images
33drifta is very attached to his balls, and would prefer not to see them in a jar perched over the fireplace :action-smiley-069:.............
lol. im sure he does like them. i quite like mine too, just i dont have a gilloutine at the door that the mrs operates everytime i go out.
list updated again.
list updated again.
come on fellas give shayno a break hes allrite lol.. you should sneek out at 6am before every one wakes up shane
Hey i'm sticking up for the guy; and trying to help him keep his manhood. :laughing-smiley-014:
alrite guys enough with the manhood talk, just thought would bring up that tonight marks only 17days til his cruis is happening. 17 DAYS... getting all so close and looks like the weather is starting to shape up for us.
bolted my turbo back up last sunday after getting it back from having a birthday (wanted to make sure it was right for its new, but still unknown, owner. They afterwards informed me it was in awesome condition but they pulled it apart an replaced all the seals etc anyway...lol.....grrr) so the cars back on the road :rolleyes:
fingers crossed i'll be free for this weekend
fingers crossed mate
hope to see you there
im makeing shore i bring enough cahs so i dont run out of fuel.
im exspection at least 1500-2000km weekend for me. so at least 4 tanks of fuel. ;)
on that note i might be looking at a 32GTR so might not be comeing depends tho.
Anyone interested in meeting at speed parts on princess highway in narre at about 8am and heading through tunnel and straight over to avalon meet point? pm me if so! Im wanting to head straight over instead of going to cambellfield sozzy ashneel n dilmah, thanks 4 the invite tho!
cheerzzzzz
brett
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
