Now also selling 2x S15 turbo injectors. $100 delivered/posted (check last post for more info)
Located in the Sutherland Shire, in Sydney.
If interested, PM me, post, or call 0401 874 604 (after 3pm).
Cheers,
Phil.
***SOLD***
Edited by Jago
https://www.sau.com.au/forums/topic/175653-sold/
hmm, perhaps the stupidly cheap prices are scaring people off? :w00t:
The adaptor plates convert stud pattern to RB26 exhaust manifold stud pattern, can use any RB26 manifolds with these puppies on. Turbos are in good condition, NEVER gone past 13psi, uses braided oil lines and high quality water lines and fittings.
Not a dodgy backyard slap together, setup isn't as laggy as you'd think either, people have been known to use laggier single setups on RB20's. Kit made ~200rwkw on only 13psi.
Need it all gone people :dry:
(if stud pattern on RB25 is the same then can obviously use this for it too, im not too familiar with the stud pattern)
Edited by Jago
https://www.sau.com.au/forums/topic/175653-sold/#findComment-3224095
  • 3 weeks later...
PM sent.
I want to know if its plug and play into the R32 ECU or is it a universal unit which needs to be wired up?
Does it have a plug where it plugs into the MICROTECH unit, then another plug on the other end? Or does it just have lose wires? :ermm:
Or if you dont know can you just send me pictures of the loom, I will be able to let you know.
Sorry for the big post. :P
Thanks,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/175653-sold/#findComment-3303619
comes with a complete wiring loom which plugs right into the microtech. It's not a bundle of loose wires. It doesn't plug into the standard unit, it is a complete replacement ECU. Will email pics if you need them
https://www.sau.com.au/forums/topic/175653-sold/#findComment-3303658
I have attached a picture of the MICROTECH that Phil is selling to help him with his sale.
This MICROTECH comes with loom to SUIT R32. This means that there is no wiring required, just plugging in the plugs as the loom has all the plugs ready to plug into the existing sensors and injectors. Pretty much plug it in and get it tuned and off you go.
The installation can be done by your self, so there is no need to get a tuner to install it. Its pretty straight forward.
2nd closest thing to a plug and play unit pretty much. It should also hold a base map for a RB20DET.
It is very well priced, and is a complete stand alone ECU. Also comes with the in-line hand controller for real life readings and tuning, which brand new is worth about $200.
Don't miss out on it if you are looking for a full standalone after market ECU, its very worth it IMO.
Phil didn't know much about the ECU so I am just helping him out with the sale, nothing in it for me.
Good luck with the sale Phil.
Thanks,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/175653-sold/#findComment-3304113
In regards to the 25, I'm not 100% sure on that, never was too sure, you'd have to check up on it yourself. But as mentioned before, and as shown in the pic, it does come with the loom. You'd need to re-tune it regardless of what motor/setup you are running it on.
As for Auto RB20, same deal. I'm not a tuner, I'm just selling what I had one my car ;).
https://www.sau.com.au/forums/topic/175653-sold/#findComment-3311440
bump.
Also adding 2x S15 turbo injectors. 444cc/min, direct replacement/fit to an RB25. All you need to do is go buy yourself another set of 4(common enough) on ns.com or something and bob's your uncle, upgraded injectors.
$100 posted
Also, please don't message/pm me/contact me and say you are going to pick up blah blah blah and never be heard from again. Stop wasting my time.
Edited by Jago
https://www.sau.com.au/forums/topic/175653-sold/#findComment-3327246
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
