Hi All
After a daring manoeuvre to avoid a stack today I have found that my stag seems to hesitate under load at approx 5000RPM for a short time then after say 500rpm it climbs to redline normally.
There seems to be a continuous popping from the exhaust a bit like hitting the rev limiter??
Any ideas??
I first thought I was low on fuel and it was starving but have 1/2 tank....
Possible that it’s missing or plugs are rooted??
Any help appreciated
Cheers
Ian
https://www.sau.com.au/forums/topic/175662-strange-hesitation/
g'day mate, iv got the Exact same problem and there has already been about 3 topics made in the last month about this problem
the conclusion that these topics come to is (generally) that its the coils
so in saying that there are 2 options to fix it, either buy new coils (standard, splitfires etc) or wrap your coils up in electrical tape or heat shrink
apparently what happens is that tiny cracks start to occur in the coil pack casing which results in them earthing out onto/around the engine covers at high load...
i haven’t done anything to fix it yet, but im hoping to buy splitfires soon to fix it
replacing the plugs wouldn’t hurt either.. hope this helps :)
How are ya Ian ?! :P
Get some new plugs;
BCPR6E
They are a 0.8mm pregapped, copper, v-groove plug. They are fine up to slightly over 300rwkw odd.
$2.80 each, so under $20 for a complete new set.
For coils, go to a hardware store and get Selleys Industrial Strength 401 high heat temp silicone, and squirt it all around the casings of the coil packs. Let it dry and reinstall. Should stop any arc. This silicone costs $15, and a silicone gun cost me $2 ;)
How are ya Ian ?! :rant:
Get some new plugs;
BCPR6E
For coils, go to a hardware store and get Selleys Industrial Strength 401 high heat temp silicone, and squirt it all around the casings of the coil packs. Let it dry and reinstall. Should stop any arc. This silicone costs $15, and a silicone gun cost me $2 :rant:
Hey Tangles, thanks for being the ever helpful guy. (You gave me the same advice), just wanted to know where would you pick these plugs up from? Do they sell them everywhere?
hey mate, sure thing no probs whatsoever
just passing on info Ive received from this very website (SAU)
Cubes gave me the plug details, and found the coil pack info somewhere around here.
For the plugs, I live in SA and got them through MotorTraders.
They are NGK brand BCPR6E. Places like Autobarn, Repco, SuperCheapAuto, etc etc would be able to get them for you.
$2.80 ish each is the going rate, so if they say $5 let me know and I can scan/email a copy of my receipt.
They are very good plugs. I will never go 'platinum' so to speak, waste of $ compaerd to these, in the long run.
How is it that everyone recommmends to replace the coilpacks with "Splitfire" C/Packs,
but no-one ever recommends the "Splitfire" Spark Plugs as well??
Has anyone out there used the "Splitfire" special split electrode plugs?
judging by what Ian is saying...seems odd that the coilpacks will act up at 5000rpm and then stabilise again above that...i would think that it would get progressively worse as the rpm climbs and the boost builds up??
but i would definately try the new plugs and silicone...even if it isnt the problem....doesnt hurt to have done the job...after all its only a matter of time before the coil packs act up.
as for the dip at 4000-5000rpm...was told by a tuner that this is a common problem in rb engines and that a safc with decent tune will do the trick
Alrighty, Supercheap said 50 bucks for a pack of 10 (Since they were bringing them in for me I needed to buy the whole pack), Autobarn said try Repco, Repco had 3 in stock and it would take 10 days for the other 3 to come in.
JShop said they would have them in by 2pm today, for under $3 per plug. (repco charged 4.20 and obviously Supercheap charged 5) Unluckily for Ian he's not in Perth =\
But hopefully I'll be a happy guy later today.
Thanks for the help :rant:
-Dervish
Get some new plugs;
BCPR6E
Brendan your the man .... have already got a set of the plugs sitting at home since my last service as supercheap had 12 in stock ..... will get the silicone this week and do a full service.....
cheers again mate.... hope that leg of yours is still going good??
Ian
i thought the same but will be the silicone/ plug trick before freaking out...
the dip in power is defrinately common problem but is definately not this that is affecting my stag.... although a tune would be nice too....
thanks again people..
cheers
ian
I had the exact same problem. I found out I was still running the original plugs. Changed for the coppers, no probs since. Of course it had to happen on the night i went to the drags, just before I got there!!!
oh well 15.4 with a misfire still wasnt' bad, but I gave up after 2 runs.
Change the plugs........ I'm sure that'll do it.
Thats it, plus its a cheap 1st-off thing to do/check (plugs and coil pack silicone).
If it still doesnt feel right, Id suggest, if you dont already have them, getting a Nismo Fuel Pressure Regulator and a SAFC and get a tune done, nice and fresh. The FPR will be important around the 4500-5500rpm mark along with the safc. Obviously a more expensive option, but once on the car you wont be looking back.
Other then that, Id be using brake cleaner (contact clean) on the AFM, squirt it out big time and clean her up a bit, maybe clean or replace the airfilter while you are at it. Sounds like a fuel / air thing,,, but you never know, could be that the timing is slightly out. 1 dyno run might help diagnose any issue you may have..........
Umm, as for knee(s), cheers lol, read the wasteland to hear what I did (accident) yesterday. ouchies. black and blue today :rolleyes: doh.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
