  • Replies 51
You wrote earlier: "and will the car be running rich after a bigger fuel pump is installed?"
Yes if your stock pump is f**ked and you replace it with an appropriate working pump then your mixtures will richen up, provided nothing else is causing it to lean out like the AFM/ECU etc.
The car will run as rich as the ECU desires, no more. which could be 10-11:1 or so at WOT
K?
  • 4 weeks later...
just got back from hyperdrive and had the same prob...
they reccomended the 040, said bout 550? i think.. for them to modify it and fit it.
not to bad i think......but if theres a direct replacment thatd be heaps better....
is the tomei one a direct replacement or does it need modifying?
They told me $550 too.
I don't want the bosch coz they don't have a pickup at the bottom of the pump. So if ur fuel tank is low or you go round corners hard it might struggle to suck up some petrol.
I think this Tomei one and the nismo one fit in a bit better too.
Or you can go for a GTR pump I'm told but meh.
If you decide to buy a pump and install yourself wanna do them at the same time? I wanna try do mine myself, just for fun. I think a few shops I asked said about 1.5 hrs labour to install.
yeh id be up for that...but if u get the tomei one get it from performance wise.....just goin thru then, there 360 delivered instead of 389 on nengun...
so thats what ill be gettin..may even splurge on a nismo one.
dont think it would be that hard to change.....*famous last words*
also they said the pickup on the bosch would have to be modified, they change the fittings for it. so the pickup would be ok on the bosch one.
This is very strange, but I was at hyperdrive last week and was told the same thing......gtr running dangerously lean....and recommended to change to a Bosh also. $550.
Are all our pumps stuffed..????..
I've been taking it easy till I get another pump and/or re-dyno.
Cheers,
Edited by PX29
I got a re-dyno at Top Racing after I went to Hyperdrive and got the same problem. So I think Hyperdrive's dyno is fine - we are just all owners of shitty aged fuel pumps lol.
that just happen to pack in within a month of each other, lol, wonder whos is next?
Well I was talking to Hyperdrive about a surgetank when I went down and they said don't bother, they run 044's intank in all their drift cars and have no problems with surge under hard cornering/low fuel levels. Don't quote me :P but they quoted me $220 to install the 044 (including fittings) because I already have the pump (got it for $214.50 delivered off ebay).
It came with a few fittings but they were meant for external use, Hyperdrive were going to supply the fittings required to go from the sock filter to the standard fuel line output. The pump is essentially bare with threads either end, you can source the fittings yourself but I figured it easier to let Hyperdrive get what they need :P
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
